Thanks to Bob and Rick.
Bob, I think the Wilwood/Sierra front pads that you supply are probably fine. Possibly they're a liittle too cool on the street as they bite really well when hot. Yes Rick, I checked run out and pad taper and found 001-003 at most, as you suggest. Also ,no bind in linkage and I adjusted as ERA procedure recommends. Don't suspect a failure in the system as it stops like hell , repeatably, when up to temps. Sorry to be a sour sister but I'm starting to think I'll have to live with noise as Bob suggests. The problem is just not responding to all this investigation. No obvious faults. EBC's are a good tip as I have used them on my Audi and Passat and also like them. I didn't know about the Girling application so I may look into that for the rears. Thanks again.
Chas.
