Old 10-15-2003, 10:58 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Solving this exact problem right now
6 speed Richmond gear tranny and Autometer programmable electric guage, electric sender on the tranny, (stock Richmond gear)... I suspect at this point that the sender is bad, since the required signal is 16 on/off square waves per revolution of the tiny shaft in the sender, @ 12VDC. It is now sending .10/.05 volts DC.. no good/insufficient for the Autometer's requirements, it wants 12 volts on/ 0 volts off, 16 square wave pulses per revolution of the shaft...
Highly recommend that you call the tech line at your speedo company, AND your tranny company, and reconcile the data... !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
