Old 10-16-2003, 07:06 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
I use the McLeod tob, and had the same problems as noted elsewhere, but found a simple fix. I noticed that the orings inside the tob did not fail, but the orings McLeod used on the banjo fittings where the source of the problems. After having a couple of failures, I decided that the original design was at fault so I combed a partshouse bin and found some orings that were rubber and brake fluid resistant and used these to replace the gum type rings that McLeod uses. No problems since the fix, well over 7000 miles ago and I use a very strong clutch set up. In spite of all of this, I would definitely recommend an external unit IF POSSIBLE, as they are one heck of a lot easier to service in case of trouble!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
