Here's what works for me on automotive wiring connections.
Automotive wiring has two enemys, 1) corrosion, 2) vibration.
The parts are basically hardware store and Radio Shack. This is a patience intensive job.
You can get bare metal connectors, or you can remove the plastic sleeve off the connectors. Removing these is important to the completed joint.
First, get some shrink tubing that will protect the joint when completed, clip a piece about 1" - 1 1/4" long, and slip it onto one of the wires to be joined.
Crimp the joint with a decent crimping tool. Then solder the joint. If soldering is impractical, than do a very good crimp job.
Coat the joint with a sealant. I use ordinary wheel bearing grease applied with a Q-tip. Vaseline (the stuff you '50's guys use on your hair) works. Spark plug boot dielectric grease will work. You just want something to keep air, moisture, and water away from the joint. A thickened WD-40 would be ideal.
Slide the piece of shrink tubing over the joint and shrink it in place. I use a Monocote gun from Tower Hobbies from my R/C modeling days. They're an electricians best friend and still only $19.95. But a good hot hairdryer will work too.
And you're done. No more pulled loose or corroded electrical connections.
