Old 10-18-2003, 02:22 AM
Rick Parker's Avatar
Default Brake Light Wiring
Well, after trouble shooting my freshly completed rewiring I realized something was amiss. I had no brake lights, and only one rear turn signal. Try as I may it wasn't until tonight that I found the error, the red wire coming from the trailer wire converter on the output side was attached to the left turn signal 4 way connector and the yellow output (left turn) was connected to the brake light switch. After correcting the above I now have both turn signals but still no brake lights. I have power from the fuse panel to the brake switch and to the Red input for the brakes. But I have no brake lights. All fuse panel fuses are good, key is on, fast blow fuses are in place, bulbs and grounds are good. I think the trailer adapter died thanks to my ass backwards (late nights) wiring. It was making a buzzing noise when I applied the turn signal prior to the change today. The pink lead from the brake switch is now attached to red lead from trailer adapter.
Rick
Trying to finish car this weekend!!!!!
