Old 10-18-2003, 11:05 AM
BB427 BB427 is offline
Cobra Make, Engine: 427SC Unique
Did you blueprint the motor? If you did ..what are the specs. for the crank,rods, thrust bearing, etc. Is this your first motor build? Are the rods in on the wrong side with the champfer to the inside? With the plugs removed can you put a wrench on the crank and turn the motor by hand? Could you easily turn the motor by hand during the shortblock assembly?
Need more info
Brent
