Parts from my build that I changed my mind on, or could not use
Some are NIB, others were on the car for a very short time. All descriptions are accurate. Ill ship parts via US Mail which is fairly inexpensive ($2-3 for smaller items, $5-10 for larger items.) Terms will be money order or check only. Items will ship when money order is received or check clears bank. You can check my seller rating on eBay, userid is gkulp (rating is perfect.) Please e-mail me or PM me if you are interested.
Thanks,
Greg
Ford Motorsport Valve Covers (SOLD!)
Polished Aluminum with black Ford Motorsport lettering. Fit SBF (302/351, will clear roller rocker assemblies,), FRPP part No. M-6582-E302P.
Bought them 2nd hand, finish has some light scuffing, one cover has a 1.25 dia. hole for breather/filler assembly. All baffles are included. $110 list price.
$45 plus shipping.
Carb Spacer (SOLD!)
1 carb spacer, open design for standard 4bbl bolt spacing. Phenolic (plastic) material. FRPP part no. M-9486-A57. Still in shrink wrap. $26.95 list price.
$15 plus shipping.
Water Outlet Connector (upper outlet) (SOLD!)
Fits SBF (302/351.) Chrome. 90 Degree. Includes gasket and bolts. FRPP part no.M-8592-B302. New, but not in box. $26.95 list price.
$15 plus shipping.
Distributor Hold-Down Clamp (SOLD!)
Chrome clamp and bolt. FRPP part no. M-12270-A302. New, but not in box. $8.95 list price.
$5 with free shipping.
Fuel Pressure Regulator
Mallory #4207 2-Port return-less (with one inlet connector and two outlet connectors, all 3/8 NPT female.) Billet aluminum. For carbureted engines. Maximum inlet pressure, 20psi. Adjustment range, 4-12psi. Includes instructions and mounting bracket/hardware. New, never used, but not in box. Came with fuel pump as a package and I am using a different regulator. $82.95 list price.
$55 plus shipping.
Oil Cooler Sandwich Adapter
Fits SBF with Ύ-16 filter fitting. Aluminum with internal bypass safety valve. New in wrapper. $31.95 list price.
$20 plus shipping.
Breather Caps
Billet aluminum, brushed finish. Push in type with rubber grommets. Never used. I dont know the list price. There are two of this item.
$10 each plus shipping.
K&N Air Filter Assembly
Complete K&N Flow Control Air Filter Assembly. Part No. 61-4030. Fits only Holley 380-800cfm carburetors with choke tower. 14 dia. 4 high filter element. Used only to start car. In original box. List price $136.95.
$95 plus shipping.
K&N X-Stream Air Flow Top Plate (SOLD!)
14 diameter K&N X-Stream Air Flow Top Plate. Black trim ring. Part no. 66-1401. NIB, never used. I ordered two of these for some reason, and only need one. $ 58.95.
$30 plus shipping.
K&N High Flow Filter Element (SOLD!)
14 diameter, 4 ½ high. Part no. CGE-3732. NIB, never used. $49.95 list price.
$25 plus shipping.
14 diameter, 2 1/4 high. Part no. e-3740. Used only to start the car, in original box. $43.95 list price.
$22 plus shipping.
Spark Plug Wires
Taylor 10.4mm Pro Wires. Spiral core, so they will work with digital ignition systems. Blue color. 135 degree boots. Universal fit, probably work best on a big block as they were plenty long on my small block. Used only to start the car. Includes complete set of wire separators. In original box. $97 list price.
$60 plus shipping.
Oil Pump (SOLD!)
High Volume
oil pump for 289/302 SBF. NIB, never used. FRPP part no. M-6600-D2. $59.95 list price.
$30 plus shipping.
Oil Pan (SOLD!)
Canton oil pan for 289/302 SBF. Rear sump, 7 qt. capacity. Part no. 15-640. Engine was shipped with this pan, but it was never bolted to the engine. Includes pan mounted dipstick ($22 option.) Needs pickup tube (part no. 15-641, $29.50.) $275 list price.
$175 plus shipping.
Holley 750 Double Pumper Carburetor
Holley 750 Double Pumper with mechanical secondaries and mechanical choke. Four corner idle adjustment. Set up by The Carb Shop as a Stage 2 carb. 70 primaries, 80 secondaries, 5.5 power valves, and .028 shooters (green.) Used only to start the car and try some initial tuning. The carb is too big for my motor, but should be great for a 351 based stroker. I will replace the power valves before shipping to ensure they are in good shape. Includes braided stainless fuel supply line with 6-AN fittings ($45 value.) $576 list price (a stock 750 DP is $395.)
$285 plus shipping.
