stroker pistons 429/460
Hi to all, haven't been on lately due to a variety of reasons, anyway the good news is that the motor now fires up easily just got to do some setting up/tuning without upsetting the neighbours!!! the fuel supply problem was a sneaky blockage in the dual inlet, I have just fabricated a set of underslung stainless pipes, and now need to sort out the mufflers from the diff rearwards. I have a couple of q's, I have just sourced another block(DIVE) which I am going to use as the next generation motor, I have a Hawks crank (4.140) and a set of 6.700 H beam rods, the block is freshly bored +60, I was going to use keith black pistons with the above combi, what alternatives do I have? what are others running with that setup? the heads will be either DOVE or if I win the lottery, ALLOY.I will probably stick with the C6 so any suggestions for a decent street cam with the 508, regards to all. Dave Keane
