Old 10-20-2003, 09:20 AM
Randall Thomas Randall Thomas is offline
Cobra Make, Engine: Three Cobras, one 351W, one 427SO, one 527BB & one GT-40 427R
Older chassis numbers (1015-ish and below) had AVO shocks and springs. One trick was to swap the front springs with the rears, but that was if you thought you were running too stiff over the rear. If not, you might want to leave it.
Chassis number 1015-ish and newer has Bilstiens (actually they began the change somewhere between 1000 and 1060) and they ride better all around.
Or you could opt for Snakebite Motorsports QA-1 shcok/spring set up from the SPF dealer in Ohio at (513)738-4000, or call Olthoff racing for their special Bilstien race shocks (NOT the same Bilstiens as comoing from the factory) at (704)647-9924.
/Randall
