Old 10-21-2003, 06:55 AM
Cobra20646 Cobra20646 is offline
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Originally posted by simonjrwinter
I've decided to get another pcv for the other rocker cover and connect them both to a couple of tubes venting under the car. I'll give it a couple of hundred miles before I make any rash judgements.
Thanks for the help guys.
Maybe I'm just reading this all wrong....... but the PCV valve should be connected to an intake manafold vacuum port. The breather on the other valve cover should allow air to 'enter' the block and be evacuated by the PVC (vacuum) into the intake.
Excessive blow by will cause the breather to puke...... normal until the engine is properly broken in.
Good luck Simon..... glad to see you have a running engine now, it's been a long journey right?
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
