Max is likely to be 80-90 lbs depending on your bearing clearances. That's a bit high for my taste. I'd suggest going back to the stock pump if possible as it's more the adequate for most situations. I recently dynoed a similar setup and the pressure touched 100. Back to the stock pump and max is now about 65.
