Old 10-21-2003, 08:05 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation That's right...
My stock Ford Racing 514 valve covers did not have ANY type of baffling at all ! So, instead of the trouble of replacing them with an aftermarket set, I used Mr Gasket rubber baffle/grommets.. you can get them from www.jegs.com I put a small wafer of breathable but stiff foam in mine also for more baffling.
Others here are totally correct.. correct PCV routing is essential..I did not realize your PCV was not even attached to the intake
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
