Thread: 428 Carb Set up
Old 10-21-2003, 05:33 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
That 292cam may make setup a bit more difficult. I have a second Holley that I had to run with that same cam in a BBC. It has a 3.5 power valve, drilled throttle blades, and more. the low vacuum at idle made it a pain in the rear, ended up much happier with a lower duration cam.
