Old 10-21-2003, 09:26 PM
Keithc8 Keithc8 is offline
Default Genesis 489FE, 719HP, 670ft/lbs
We just finished one of the 427FE's we are doing with the Genesis blocks. This engine was a 4.280 bore with a Scat 4.250 cast steel crank and 4340H-beam rods with JE pistons. This engine had one of our custom hydraulic rollers with about 12 to 1 compression. We used a stage 2 Edelbrock head with a Dove single plane intake. The carburation was one of our 950HP DaVinci craburators with a cnc 2 inch spacer. This engine idles at 900 rpm's and makes power to 6800rpm's. Max tourqe is at 4600 to 5000 and the max horsepowers is at 6300 to 6400 rpm's. The tourqe being between 660 to 670 in that range and the power peaking at 719 while still making 710 at 6700rpm's. This is one of our crate engines with the Genesis block up-grade and longer stroke. This engine sold for 15,800.00 complete of the dyno. Let us know if we can help with any of you FE engine needs. Bringing the FE engine into the 21st century.
Keith C
