Thread: 428 Carb Set up
Old 10-22-2003, 10:48 AM
RedCSX RedCSX is offline
Default Intersting- My Cam is.......
The custom ground cam from cam research is a solid lifter 242/242 @.050 with 590 lift. The heads and intake are really going to be worked over and plan to go with a Mighty Demon carb. I will have the whole set up tuned on the dyno before it goes in the Cobra. Just got off the phone with the guy porting the heads and intake (blue thunder) . He said the intake was very restrictive and needed a lot of work improved the center port by 40 cfm. Told me to check the exhaust that comes with it. Could be very restictive, said he has seen guys lose 100 HP because of the exhaust.
Morgan
RedCSX
