Ok, bringing back an old thread. I think I know whatI'm going to do. I was good throttle response and god mid-range torque and horsepower. So, lets hear your opinions!
-stock 302 block and pistons.
-Miloden
oil pan
-Edelbrock Performer RPM intake
-Holley 650CFM carb
-windage tray
- Either:
Edelbrock Performer RPM heads with the 1.90" valves OR....
Edelbrock " " w/ the 2.02 valves (dremel the piston clearance notches bigger.)
-Cam with 224/236 @ .050, .490" intake .510" exhaust....110-112 lobe seperation (not sure brand, but prettty set on the specs)
-Edelbrock 1.7 roller rockers
-stock pushrods (they will still work, correct)
-stock lifters (same question as above)
Extras:
-upper and lower control arms (or just bushings)
-Pro 5.0 or Steeda T-5 shifter
-Edelbrock water pump
One more question: Where can I get a taller filter for my oval assembly. Mine is only like 1 3/4 inches tall, where as I've seen some oval filters that were around 4-5 inches tall.
