Thread: Relay Switch??
Old 10-23-2003, 02:35 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Jack, this is the way I wire the relay.
The relay terminals have #'s 30, 85, 86,and 87 stamped next to them.
#30 goes to the positive terminal on the fan. Run the other fan wire to ground.
#85 connects to wire 151 or an ignition power wire.
#86 runs to the temp sender.
#87 runs to the circuit breaker power side or direct to the battery.
To hookup the over ride switch, remove wire 161 from the switch and replace it with a ground. The other side of the switch has wire # 157 which you can hookup to terminal #86 on the relay.
Wire #151 and #157 run along the drivers side frame rail close to the upper control arm.
Don
