Freddie, i took out my windscreen washer tank and button, it got hot and leaked out the nozzle, dribbling on the hood anyway. I got the aircraft momentary-0n toggle switch with the flip up aircraft cover, i just put it in the hole, ran the green wire from the starter to it, then to the solenoid. So on with the key, flip up the cover, hold the spring loaded metal toggle up to spin the starter, and let it go when it fires, i usually then flip down the cover. In the past, i have neglegently turned the key on a running motor, this fixes that mental lapse. The switch fit fine in the push button hole.
hal
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
