Randy,
Cal is correct, the webbers are great carbs that just takes awhile to understand them. I had webbers on my cobra for 8YRS and they were on my 34 Ford before that. The only problem that I experienced with them was when I went up to a high altitude. They loose power quickley and use gas at twice the rate. They will snap crackel and pop until you get back to the altitude they were set for. So if you plan on any trips to Flagstaff then you might want to preset them before you leave..
Hersh
