CJ:
The "small third hand" is a needed tool in any ham fisted male's tool box. Wait til you try to work on an ERAGT. This is when I call on the 105lb spouse with hands about half as wide as mine to come help out "for just a minute" It costs me every time.
J
PS: The alternative is the "turn the other rear nut on a thread or two and then slowly lower the seat down as you tighten up on the other, locate the front into the holes, lower turn on a few threads, then go around to each nut and tighten the whole seat down a few turns at a time, etc. etc.
Because of the problems that I have had with my hydraulic clutch we've had the trans in and out of my ERAFIA about a half dozen times until we changed the banjo fitting to a heavier brake style fitting. Sometimes I wake up screaming in the middle of the night.
