Thread: tonneau cover
Old 10-31-2003, 09:19 AM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
If you're reasonably handy you can do it yourself. I fitted mine myself with good results...a hole punch will be useful. Mine had self-adhesive felt pads that stick to the bottom of the "lift-a-dot" fittings to protect the paint. Art is right, if you go with a kit, be sure it has a provision for the roll bar, and fit it as snug as you reasonably can. Also, those dam%#$@&** body pins are fragile little buggers, don't overtighten, and make sure the hole is big enough to screw 'em into...twist one off and you got a "wee" little problem...
Ken
