Thread: 351c Decode
Old 11-02-2003, 08:25 PM
Daniel Jones Daniel Jones is offline
> 351C FORD V8 FROM A ISO RIVOLTA
What year Iso is that? I knew Iso switched to 351C's in the later
Grifos, Leles, and Fidias but I thought the Rivolta were all Chevy
powered.
> THE BHP -C/R
The early high compression 4V's were rated at 300 HP (SAE gross)
and later low compression 4V's were around 266 HP (SAE net).
> HEADS 1020 61-53 DIZ DA 3 4V
Those are probably D1ZE-DA heads which are open chamber and will yield a
compression ratio closer to 9:1. Jim, were your heads D1AE's? Those
are the high compression heads that yield 10.5:1 with flat top pistons.
Two pack, the best way to be sure is to CC the compression chambers.
The open chamber heads will be around 76 cc's and the closed chamber
heads around 64 cc's or less.
Valve train failure is the number one failure mode for a Cleveland. The
stock valves are two piece with loose fitting multi-groove keepers. If
they don't slip out of the keeper, they'll pop the head off. I learned
that lesson the hard way on a newly rebuilt standard bore engine. Punched
a fist size hole in the side of the block.
Below, I've attached some general 351C tips that I put together which you
may find helpful.
> MANIFOLD DIZE 9425BB
> CARB D2ZFBB DIL13
Are the holes in the carb and manifold approximately the same size or
are the primaries smaller than the secondaries?
> BLOCK D2AE CA
D2AE-CA can be either a 2 bolt or 4 bolt main block. Drop the pan
and see. Also check the oil pan for a crank scraper and baffle plate
around the pick up.
> IT HAS FLAT TOP PISTONS AND 2.19 INLET VALVES
Okay.
> WHAT CAM CARB MANIFOLD I WOULD NEED TO GET 350 -400 BHP FOR STREET USE
A Blue Thunder dual plane high rise intake would likely be your best
bet. Available from Marino Perna at Panteras East.
> THANKS TWO PACK UK COBRA CLUB MEMBER
You might try contacting the UK Detomaso club. Panteras also came
with 351C's (and ZF transmissions). They might be able to help you
with local sources of parts.
Dan Jones
Some basics of Cleveland building (in no particular order):
- Use single piece stainless steel valves with single groove keepers. Valve
train failure is the number one failure mode for a Cleveland. The stock
valves are made from two pieces, friction welded together. They also use
loose fitting multi-groove keepers (the keepers halves contact each other
instead of being wedged against the stem by retainer.). If they don't slip
out of the keeper, they'll pop the head off. Unfortunately, I learned this
lesson the hard way. Aftermarket tight fit multi-groove keepers and valves
are available but most just switch to conventional single groove valves and
keepers.
- The 351C block is a thin wall casting with a fair amount of core shift.
Keep the overbore to a minumum and don't exceed 0.030" without sonic
checking. Individual cylinders can be offset bored to maximize wall
thickness. 1/2 fills of the water jacket with Hard Block (essentially
furnace cement) can stiffen the bottom end an cylinders and still be run
on the street.
- The rubber intake manifold gasket end seals can be troublesome, especially
if the heads and/or intake have been milled. Many builders toss the rubber
seals and just lay down a bead of RTV. I don't like this as I've seen too
many engines with RTV bits clogging up pushrod holes and oil pick ups. I
prefer to buy or make my own end seals from cork. I peen the block rails
with a punch so the gasket won't squeeze out while it's being torqued down
(a problem when the heads have been milled but not the intake). This also
works well on valve cover gaskets. Use Permatex 300 or a contact cement
to hold the gaskets in place. Don't use RTV except in the corners of the
end rails and even there I prefer using the red/brown hardening Permatex
(different from the black 300 Permatex). Retain the turkey pan unless the
carb heat ports are blocked. The pan protects the oil from splashing on
the hot exhaust crossover port and turning to ash.
- If you retain the stock rocker arms, make sure you use the steel 4V sled
fulcrums. The 2V fulcrums are aluminum and can come apart under load.
Also, there are two types of stock rocker arms (lugged and unlugged).
The ones with the lug on top may have a clearance problem with cams of
0.550" or greater lift. The pushrod tube may contact the lower position
of the rocker arm when the valve is fully open. This can bend or break
the pushrod. Given the high lift of the typical Cleveland performance cam,
roller rocker arms are a good investment for increased valve guide life.
The strongest roller rockers are the stainless steel ones from Crower,
Comp, and Norris. While they may weigh more than similar aluminum roller
rockers, the mass is concentrated at the stud so the extra inertia is
minimized. Stay away from the inexpensive, imported, aluminum roller
rockers as many are poorly made. Good aluminum roller rockers will last
a long while on most street/strip engines but very high spring pressures
can split the bodies in half. Always disassemble new roller rockers and
clean them. You may have some clearance issues with roller rockers and
the valve covers. If your valve covers are equipped with drip rails (as
Boss/HO cast aluminum and even some factory steel valve covers were), you
will have to remove them or bend them out of the way. You may also have
to clearance the rockers arms near the oil filler and PCV baffles. Use
the real FoMoCo rubber valve cover grommets. The repos just don't fit
right and will leak. Fel-Pro makes a thick three layer (cork-metal-cork)
valve cover gasket that can make the difference with clearance problems.
Permatex the gaskets to the valve covers and run them dry on the head side
if you plan on frequent removals. It is possible to run adjustable valve-
train, roller rockers and a stud girdle under a Boss aluminum valve cover
and there are spacers if more room is needed. Ford Motorsport also makes
tall polished aluminum valve covers.
- Drive a second shear pin in the distributor gear or replace with a hardened
pin. If a little debris (see valve seals below) gets in the pump gears, it
can shear or bend the pin. This retards the timing which leads to sluggish
performance and overheating, if the engine manages to continue to run at
all.
- Don't use umbrella valve seals. Use the blue or black viton seals. The
umbrella seals disinegrate over time and fall into the pan where they get
sucked up by the oil pump, momentarily locking up the pump and bending the
shear pin. Newer umbrella seals may be made of a more durable material
(the last rebuild gasket set had a note to that effect). The white Teflon
seals with the upper ring are too effective and do not allow enough oil
past for guide lubrication. This can lead to a stuck valve or prematurely
worn guides and/or stems.
- The usual Ford oil filter has a bypass valve bult into the filter which
can allow unfiltered oil to bypass the filter. The bypass can also fail,
causing a loss of oil pressure. Consider using Purolator oil filter
number L30119. It's a full size replacement for the FL-1A Ford/PH8A Fram
filter. It has no bypass spring in the middle but it does have the rubber
flapper for anti-drainback. The original application is for a 1978 Nissan
510, 2.0L 4 cyl engine (L20B) which had the bypass valve in the engine
block. This filter cross-references to a Fram PH2850, a Motorcraft FL-181,
and a Wix 51452. However, those filters have not been verified and may
still have the bypass. It appears after 1978, Nissan went to a half height
filter. Purolator part number L22167 fits that application and does not
have the bypass spring but does have the rubber flapper for anti-drainback.
Serious engines may want to run dual filters.
- The stock rods are good to 7000+ rpm with prep. At a minimum, use good
(ARP) rod bolts. Beam polishing and shot-peening are also good but
optional.
- Run a PCV valve.
- Use a Cleveland specific thermostat. They have a shoulder which is sized
to match the brass restrictor ring in the block (make sure it's there)
which other thermostats do not have. Using a Windsor thermostat (which
the parts counter monkeys will give you half the time) will lead to over-
heating because coolant will bypass the radiator. Don't run an excessively
cool thermostat. It won't make a difference in steady state temperature
but will slow warm-up time. I recommend the Robert Shaw 351C thermostat.
It's quick acting and has bleed provisions (ball bearing check valve).
- 4 bolt mains are a nice-to-have but not necessary for most applications.
- If the car is set up to handle, use a baffled, oversize, oil pan. A stock
Pantera with slicks can pull over 1.0 g's lateral and the oil in a stock
pan will climb the side of the pan starving the bearings for oil. I know
two Pantera engines that were ruined that way.
