Old 11-03-2003, 07:53 AM
PatBurke PatBurke is offline
Default Fairlane rear gears
Depending on the time of year (weather conditions) and tire size we use a couple of different gear sets. the car has a 9" rear with a Mark Williams thru bolt aluminum housing, 40 spline spool & axles, and ball bearing aluminum pinion support. We use Richmond "pro gears" and with 31" tires we use 5.67's in cool weather and 5.83's in the heat.
Thanks, Pat
