Old 11-14-2003, 08:25 AM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Postscript - Very, VERY, important. Don't forget to check the torque settings of the flywheel bolts after you run a aluminum flyweel for a while. I can't emphasize this enough. Yes I know in most cases that means pulling the clutch. It would be a good time to check those pressure plate bolts/torque anyhow.
cobrashock
Ron Shockley
