dvcobra,
First off, what is, custom classic roadsters sway bars? Never knew they had any sway bar but one.
When you installed the SM600's did you mount them in the original frame holes or did you drop them down a little?
The rest is just a matter of tweaking to your own personal tastes.
I know we add a wee-tad of toe-in for the track, but this is really Jay's forte. I'll see if I can't pull him away from the shop long enough to jump on here and help on this.
As I have said many times, we have found the front "stock" CR's sway bar to be way to heavy for the car. We simply unhook it, or leave it off completely, and use the rear bar only. We have done hours and hours of skid pad testing and this set up produced the best results with exactly the same set up as you have.
DV...It's cookie time
