Old 11-16-2003, 09:52 AM
Brad Long Brad Long is offline
Cobra Make, Engine: Black Shell Valley with Silver stripes, 351 "Cleavor" powerplant
Thanks for the advice. I'm going to pick up an issue of that mag today! Another question out of curiosity - Are you running an electric fuel pump? What kind do you have and where did you mount it? Did you have problems with pick-up on the suction side? The outlet on my tank is at the bottom, and I've been told that most electric fuel pumps need to be mounted close to the outlet and at the same elevation to avoid cavitation and suction problems (gravity feed). I plan to try a Holley "Red" mounted about six inches above the tank outlet with an inline fuel filter before the pump. I will have about 12 inches of line from the tank to the pump. Any suggestions from experience?
