Thread: Prices Reduced
Old 11-19-2003, 11:41 AM
Greg Kulp Greg Kulp is offline
Default Prices Reduced
I've reduced the price on the parts that have not sold, there's some good stuff left. See previous thread "Various Parts for Sale" for what you missed. These are parts from my build that I changed my mind on, or could not use… Some are NIB, others were on the car for a very short time. All descriptions are accurate. I’ll ship parts via US Mail. Terms are money order, PayPal, or check. Items will ship when money order is received or check clears bank. You can check my seller rating on eBay, userid is gkulp (rating is perfect.) Please e-mail me or PM me if you are interested.
Thanks,
Greg
Fuel Pressure Regulator (SOLD!)
Mallory #4207 2-Port return-less (with one inlet connector and two outlet connectors, all 3/8 NPT female.) Billet aluminum. For carbureted engines. Maximum inlet pressure, 20psi. Adjustment range, 4-12psi. Includes instructions and mounting bracket/hardware. New, never used, but not in box. Came with fuel pump as a package and I am using a different regulator. $82.95 list price.
Now $35.00 including shipping in US.
Oil Cooler Sandwich Adapter
Fits SBF with ¾-16 filter fitting. Aluminum with internal bypass safety valve. New in wrapper. $31.95 list price.
Now $15 including shipping in the US.
Breather Caps (SOLD!)
Billet aluminum, brushed finish. Push in type with rubber grommets. Never used. I don’t know the list price. There are two of this item.
Now $15 for the pair including shipping in the US.
K&N Air Filter Assembly
Complete K&N Flow Control Air Filter Assembly. Part No. 61-4030. Fits only Holley 380-800cfm carburetors with choke tower. 14” dia. 4” high filter element. Used only to start car. In original box. List price $136.95.
Now $75 including shipping in the US.
K&N High Flow Filter Element
14” diameter, 2 1/4” high. Part no. e-3740. Used only to start the car, in original box. $43.95 list price.
Spark Plug Wires
Taylor 10.4mm Pro Wires. Spiral core, so they will work with digital ignition systems. Blue color. 135 degree boots. Universal fit, probably work best on a big block as they were plenty long on my small block. Used only to start the car. Includes complete set of wire separators. In original box. $97 list price.
Now $50 including shipping in the US.
Holley 750 Double Pumper Carburetor (SOLD!)
Holley 750 Double Pumper with mechanical secondaries and mechanical choke. Four corner idle adjustment. Set up by The Carb Shop as a Stage 2 carb. 70 primaries, 80 secondaries, 5.5 power valves, and .028 shooters (green.) Used only to start the car and try some initial tuning. The carb is too big for my motor, but should be great for a 351 based stroker. I will replace the power valves before shipping to ensure they are in good shape. Includes braided stainless fuel supply line with 6-AN fittings ($45 value.) $576 list price (a stock 750 DP is $395.)
Now $225 including shipping in the US.
Greg
America. Home of the free, because of the brave.
