Old 11-19-2003, 03:59 PM
K.Wilson K.Wilson is offline
Club Cobra Member
Send a message via AIM to K.Wilson
I believe what Brian said refered to the C axis or the rotation of the lifter in the bore. not the X axis which would be the with the roller up or down in the bore. In this case Brian is correct the triangle or "V notch" is on the "Down" side (as he said toward the piston), or is "pointing toward the water jacket", not rotated 180 degrees in it's bore and pointing toward the intake manifold. If installed this way the lifter roller will always turn in the same direction.
Hope this helps. Keith
