Hey Jack21. I can't find any reference to the upper control arm adapter on the Bethania Garage website. Do you have more details?
Finishline has a similar (?) adjuster on their website. Anyone had experience with it?
Also looking for some opinions on the following :
I would like to drop my front end (Mustang II with tubular arms and coilovers) another inch to make the stance right, but I do not have any coil adjustment left. So , should I go for a shorter spring/shock setup , or should I use 2" dropped spindles and my current coilovers adjusted up an inch to get my net result, 1" lower.
And :
In order to get the Sunburst wheels to fit properly inside my front wheel lip, I need to narrow my track by 1" on each side. I am thinking of using the 1" narrower upper and lower arms from Speedway.
Any help/advice is appreciated.
Greg
