Old 11-21-2003, 08:35 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Fixit is right. No lag. Adjust it so that as soon as the throttle begins to move it immediately begins to activate the accelerator pump. According to Holley there should be .015 clearnace between the pump arm and the pump lever when the throttle is in the wide open position, but the pump should be activated as soon as the throtte begins to move.
Replica is not a dirty word.
