Definitely want to trim off the bottom of those aftermarket scattershields if you don't want to have an unfortunate situation on the street where there are uneven road surfaces. Pretty standard procedure on the Lakewoods; especially FE and Big block cars.
However, I've heard that some strips wont let you run if its a modified SFI approved housing. For street use, you almost have to do it if the motor is mounted low or if your Cobra sits lower...
Duane
