The engine ran, and I am positive of TDC (compression, #1). I am not clear about rotating
oil pump. Would this not change the timing ..180 degrees? If so, is this a problem, or would this just reset timing sequence?
I am planning on installing a new distributor,(MSD) but with all the changes I am making I was trying to reduce the "unknowns" . IE when engine refuses to fire up after all my changes, I wanted to reduce the potential "ROOT CAUSES".
Thanks for your ideas!
