Old 11-23-2003, 05:58 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Mike:
Check out this ERA Alternator Wiring Diagram from the ERA website:
www.erareplicas.com/427man/wiring/alt.htm
also try this link as well...
http://www.erareplicas.com/427man/wi...or/trouble.htm
Hopefully this can help. ALso, check the Manual Supplement, (Wiring Your ERA 427SC).
I am not personnally familiar with the PowerMaster alternator.
However, the alternator should be grounded thru the Black Wire as well as thru the case thru the bracket to the engine block.
So make sure to try a continuity test of the alternator case and the block. Sometimes a heavily painted alternator bracket can insulate this needed ground.
Hope these pointer help amigo!
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
