I just went out to look at the engine and you might mean
oil is resting by the plug right behind the intake manifold not on the intake. If that's the case and
oil is on the back of the engine behind the intake the rear gasket might be leaking causing a massive vaccume leak causing the engine to run lean.
Tony
