Well, I don't know about .25", I ran .50" fuel line on my mod and 5/8" air craft quality rubber line where needed. This was with a 15# pump and regulator at the carb with a return line. Stainless is better in the fact that crud and deteriation are not common. Aluminum works fine as long as you maintain your fuel delivery system. Keep it clean, good fuel, store it properly then this system will work well for long periods of time. Stainless is lower maintenance and doesn't damage as easily. FWIW, Les
Tohmer
"Ask not what your country can do for you, but what you can do for your country" JFK
