Old 11-25-2003, 01:18 AM
750hp's Avatar
750hp 750hp is offline
Cameron - what are your goals, and what sort of budget are you on? Basically, if you want to spend $1000 and want maybe a new cam/carb/manifold fitted to the engine in your car, most places should be fine with that.
If you're removing the engine, and plan on building a bit of a monster, I'd recommend either Tony O'Connor from TOCA Performance 3209 1606, or Steve at Cragar Performance on 3800 1958. Cragar dyno tuned my motor, and did a wonderful job! They are also contracted exclusively to Steve Ellery's V8 Supercar team for engine building and data analysis. Cragar are also previous Australian Pro Stock drag racing national champions. All Ford products, too!
Tony builds engines from his house, so his overheads would obviously be a little lower than Cragar. This might or might not be reflected in the engine cost. Both definitely worth a call though...
Craig
