Old 11-25-2003, 08:08 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I'm running an Isky solid lifter cam in my 428. .530 lift, 240@.050 for both the intake and the exhaust, 108 LC. I couldn't be happier with it. It has a really nice lopey idle and it pulls strong from idle all the way up to 6000 rpm at which point the rev limiter kicks in. Prior to this cam I was running an Isky hydraulic. .565 lift, 232@.050, 108LC. Surprisingly, I don't notice much of a difference between the cams at higher rpms, but the solid lift cam pulls much stronger down low. According to Desktop Dyno, the hydraulic cam should be giving me about 458hp@5500 and 493ft-lbs@4000. The solid should be giving me about 500hp@5500 and 511ft-lbs@4000.
Chris
