Old 11-26-2003, 12:47 PM
Rick Parker's Avatar
Use a fine tooth file to remove the sharp edge around the perimeter of the tube prior to the first flare, also debur the inside before you begin forming the first flare. Practice on a piece of similar tubing material before you start on the actual pieces you will be using. A little lube is ok too.... Good luck
Rick
