Old 11-27-2003, 06:58 AM
strictlypersonl strictlypersonl is offline
I wouldn't do it.
You will run into several problems:
You will need a custom pilot bearing that extends toward the trans.
Your clutch driven disk splines may not "overlap" with the input shaft well. If you could find a disc with a different offset, it might interfere with the pressure plate or throwout bearing.
Your transmission mount won't line up.
IMHO, t'aint worth the aggravation.
