Given the proximity of the flywheel and clutch components to your legs and other important body parts, the use of a stock style bellhousing is not recommended. For your own safety, invest in a good scatter shield and your new clutch will work just fine. Lakewood is a good source and make sure you get the block plate along with the housing as some places sell them separately to make the price seem a little better. Follow the instructions on aligning the scatter shield to the crank center and you will be set.
Gary
