Hi Tom. Same headers and mounts if you use a windsor. Clevelands are total different puppies. The only difference is the 351 will sit up a little higher and the cutouts in the body for the sidepipes will be about an inch or inch and a half higher. If and when you do the change over, let me know, I'll give you some tips to make it easy.
Nonconformist. Can't handle a real job.
