Old 11-29-2003, 11:22 AM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default clutch trouble...won't disengage
I’m having a heck of a time with the clutch on my Kirkham. Here are the facts:
The car is in the process of assembly, and all clutch parts are new....it hasn’t run yet (and the way I’m goin’ it maybe awhile!).
427 engine with 4 speed toploader
Centerforce II disc and pressure plate, correct mechanical T/O bearing
3/4” Wilwood Master
1” Wagner Lockheed slave
Lakewood bellhousing
Problem: I can’t get the clutch to completely disengage.
What I’ve done:
Hyrdraulics of the master and slave are leak-free, and bled several times...no air in system.
The fork and scattershield have been modified so that there is nothing rubbing on moving parts to obstruct their travel.
The pedal pressure is reasonable and the transmission input shaft fit smoothly into the pilot bearing...bolted up easily.
The pivot bracket within the bellhousing has been shimmed as much as possible to create the best fulcrum for the clutch arm and the “vertical” piece of the pivot bracket is on the inside most part of the housing (which is correct, I thank).
The master cylinder and the slave as well have been adjusted “out” as much as possible to move the T/O bearing as much as possible.
Despite this, the clutch won’t totally disengage...with a strong effort, you can barely rotate the output shaft with the car in gear and the clutch to the floor.
Any thoughts on this? I was thinking about going to a larger MC, maybe a 7/8”, but Wilwood doesn’t make one for this application. Could go to a smaller slave, maybe a 7/8” there with the 3/4” Master. I’ m totally befuddled here. thanx steve meltzer, KMP #174
steve meltzer
"I may be wrong, but I'm never in doubt"
