Of course it depends on the mechanical advantage of your clutch pedal, but we've found that the diameter of the clutch master and slave should be about equal. In fact, some small block clutches require a larger master cylinder diameter to fully release.
If you're using a standard clutch throwout arm, you'll need approximately .7" of throw where the slave linkage connects.
