Old 11-29-2003, 02:30 PM
steve meltzer steve meltzer is offline
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Thanx to all for your prompt replies. I'm certain that the disc is facing correctly...it was labeled as such from the factory. All of the slack is out of the linkage, but the only return spring is from the arm to the engine, to return the arm after it is actuated.
We put the drive shaft yolk on the output shaft and used an 8" pry bar to rotate the shaft.I'd say it took about 40-50# of force. It seems like you could hear the disc against the flywheel.
I'll have to measure the throw of the slave linkage.
thanx again.
steve meltzer
"I may be wrong, but I'm never in doubt"
