Jerry,
I've got a 393W stroker. It has Roush 200 heads in cast iron flavor, 9:1 compression, and fairly stock bottom end. Don Scott told me what cam to use in this car, and I think he was right. It's a competition cams with a lift of .544/.541 and a duration @ .050 of 246. It doesn't like being driven much below 1900-2000 rpm but it can if throttle is controlled nicely. I had the car on the chassis dyno at the spring fling this summer and with a 3.55:1 rear axle ratio I made 360 rwhp and 398 lbs. ft. of torque from 2750 to about 5000 rpm. The torque curve is as flat as a pancake and the hp is a very linear curve upward. This is a very controllable motor that STILL spins the rear tires in thrid gear when the meat of the power comes in.
Jim Downard
Man, it would've been helpful to know that cop was behind me a minute ago!
