Check to see if you have any burrs where the brake hose hooks to the caliper. The copper washer should seal just fine. Are you using mechanical linkage on your clutch or a hydraulic throw out bearing? I found that about all the slack needed to be taken up in the linkage for the clutch to disengage properly when using the hydraulic slave cylinder.
hog
