Excerpt from a previous posting received from the ctemissions program manager, which indicates the year used for the vehicle on the registration will determine whether an inspection is needed:
To quote:
At the end of this message is an excerpt from the regulations defining special interest vehicles. It is available electronically and in its entirety at
http://www.cga.state.ct.us/2003/pub...#Sec14-164c.htm
However, to re-state, the determination of whether your vehicle needs to be emissions tested is based upon its registration, for example a 1925 Model T with a 1974 engine that is registered as a composite vehicle in 1999 would need to be tested because its registration date is as a 1999 model year. For your particular vehicle, you need to check the registration to determine if you need to bring it in.
