Thread: Distributor
Old 11-30-2003, 09:31 PM
Unique580hp's Avatar
Unique580hp Unique580hp is offline
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
I also have a Pertronix Ignitor II unit in my Cobra along with their Flametrower II. It installed in a minute and works great.
(Note: If you do use the 45,000 volt Flamethrower II coil, you will have to run a separate wire from the ignition switch to the positive side of the coil to bypass any ballast resistor wires. The coil needs a full 12 volts)
1st car was a Cobra, hopefully my last will be also!
