Thread: Selling my Car
Old 12-01-2003, 09:19 PM
concobra concobra is offline
Cobra Make, Engine: Contemporary / FE
Thank you guys so much for the help. I will list some of the car features. I hope you do not think me boastfull.
1993 Contemporary Cobra
SC design
Miles: 2500 car & 500 engine
Color: Midnight Metallic Blue with white stripes
Paint: Glassurite ( Same type used on Mercedes Benz)
Condition of paint: Excellent
Engine: FE Ford 451 CID
Block: 427 side oilier cross bolt ( Not a service block )
Bore: 020" over
Fasteners: ALL bolts & studs and ARP
Crank: 428 ford IUB Super Cobra jet
Rods: Lemans, Magged, Polished, Double Shot Peened,
Pistons: Custom Ross flat tops yeilding a true 10.57:1
Heads: Eldelbrock & CNC ported by Jim Kunse
Valves: Ferria ( I didn't spell this correct)
Retainers & locks: Crane Posi Titanium
Rocker Arms: Dove custom with .125" offset and modified for better oil control ( will not scuff)
Pushrods: Smith Bros Custom 3/8" super heavy wall
Lifters: Crane Roller offset pushrod
Cam: Cam Dynamics custom grind
Cam Drive: Milodon Gear
Oil Pump: Precision High Volume & Pressure 5/16" drive with heavy duty drive shaft ( Oil Pressure hot 40# idle & 70-80 @2000-3000
Intake: Edelbrock Victor ( Modified for hood clearance and altered pushrod hole location for no port restriction)
Ignition: All MSD ( Dist, 6AL, Coil, Wires, Manual Retard) All under the dash on custom modular unitized board with plug in terminals.
Carb: Custom built by Pro systems Holley 1000 cfm HP. Modified 3 circuit design.
Oil Pan: Canton 8 qt Road Race with custom windage tray.
Flywheel: Aluminum
HP & Torque: 540 ft lbs @ 4300 & 540 HP @ 6000 Dynoed.
NOTE: This motor can produce much more if desired with a more aggressive cam. I did not think that it needed more. It is over built both reliablity and HP potential than it currently makes. I like to be conservative here.
Radiator: Griffin twin 1.25" core.
Fan: Vintage Air Monster Fan over 4000 cfm pull with custom shroud. (THIS MOTOR DOES NOT EVEN COME CLOSE TO EVER OVER HEATING. RUNS 160-180 EVEN WITH AIR TEMP OF 100 DEGREES)
Fully Shrouded intake side.
Clutch: Centerforce
Trans: Ford Big shaft top loader
Rear Suspension & drive: Jag
Dana 44: with 3.54:1 Posi
Cover: T&D girdle with Carrier Bearing supports
Half Shafts: Tubular with heavy duty "U" joints
Lower "A" arms: Stock jag with custom made radius rods running forward on the frame. Well engineered and looks like the car was designed for this. Really strengthens the "A" Arm.
Hub Housings: Accurate Machine with Watts Linkages. Modified to strengthen the pivot point.
Front Suspension: Jag with coil overs
Lower "A" arm: Custom made back half for increase strength
"A" arm pivot points: Billett Aluminum and modified to move tires under wheel well for better appearance.
All suspension parts are powder coated
Shock: Front & Back are Spax fully adjustable
Brakes: Front Willwood & Back Jag stock
Wheels: Trigo Pin drive with 6 pin
Knock offs: Halibrand
Trunk: Custom Aluminum panels like the SC cars
Engine Compartment:
No exposed wires
All hoses are braided and symetrically routed
Brushed Aluminum fire wall
Brushed Aluminum header heat sheilds that are double insulated
( NO HEAT TRANSFER INTO CAB AND NO HEAT DAMAGE TO BODY)
Interior
All Smith Gauges (Modified for reliability)
Dash is reinforced to resist vibration
All Electrical Connection are quick disconnect type and dash can be removed in less than 10 minutes.
Carpet: Wool
Seats: Leather
Pedal Assembly:
Custom Under car with Modular design
Dual Brake Master Cyl with mech. bias adjustment & additional Hyd. Bias adjustment in the cab.
Misc.
All fasteners on the entire car are ARP Stainless steel.
Underside of car is detailed
I designed the car to be very easy to service:
All attachment points are designed to be installed and removed from one side of the fastener. No through the body nuts and bolts.
All Electrical is modular, marked, relayed and easy to access.
I can pull the engine and have it on a stand by myself in two hours and can reinstall in four. That includes trans and side pipe removal.
Everthing on this car fits with extreme precision. It slips together.
In building this car I would not compromise on any fit and finish issues. It had to go together as perfectly as I could do. Before I proceded with any part. That part must look as if it was engineered it work and fit in that location and must be easily servicable.
It truly is a maintenance free and very dependable car.
Car did win the best Cobra at the All Ford Car show in Portland, OR 2003.
Car starts easy. Runs extremely well. Doesn't give the owner any worries while driving it. Nothing left to sort out.
Price: $55,000.00
Sorry about the mis-spellings
