There are a couple of factory lengths relative to the stock locations. I think you'll find that the mustang rods for the rear mount on the short tailshaft will put the shifter where you want it. My short tailshaft only has the mid mount and I have a plate to move it to the rear location. I think the hurst plate for a Boss 429 is the one that will do this. If you are using a sock ford shifter the plate is a little harder to make. If you use a Hurst shifter the plate are easier to make. Gman
